How difficult is it to replace a Festiva head gasket and timing belt?
I have a '92 Festiva that needs a head gasket, so while it's apart, I want to change the timing belt as well. I got estimates from 2 different repair shops. One of them said $1,110 and the other one said $968. Is this job THAT labor intensive? I'm not a mechanic, so I don't know all of whats involved in this job, but that seems like a LOT of money. How many hours should it take to do this? I know the gasket set is $89 and the head would have to be machined a little, so I figured the job should be between $400 and $500. Is there something more difficult about this job than it looks like on the surface?
Thanks,
Bryan
Thanks,
Bryan
It is a pretty detailed job for a Novice, what you got to understand is ALL your major external engine components basically have to be removed, as well as battery, intake manifold, exhaust manifold, draining oil and antifreeze. Timing belt and cover. LUNCH AND BEERTIME! Cylinder head bolts are removed and installed in 1/4 inch increments AND a particular sequence to keep from warping the head; removing AND installing it. The YARD motor is better deal then replace at your leisure and education... the heads. Festivas are great cars but also touchy. Figure on 6 hours work in a PRO shop, including head resurfacing. Calculate your parts costs and labor costs per hour and there you are except for usual shop expendable parts fee and taxes and dinner for mechanic. Let me know!!! For 1100 dollars I would drive there and do it myself!!!
