Originally posted by hawkdoc60
Alternator belts
When I replaced the alternator, I had to replace the bolts, too. The prior owner rethreaded the alt with SAE threads and bolts. As a result, they never tightened quite right. I had to add a jamnut to the top bolt. When I replaced the bolts with new metric bolts, I made sure both were tight.Originally posted by MONSOON View PostAre you making sure youre tightening the lower bolt and not just the upper bolt. Bella was doing the same thing and then I discovered that bolt. Tightened it down and bingo no more troubles.
Sorry I didn't answer this right away, I missed it somehow while scrolling the first time.http://www.cardomain.com/id/hawkdoc60
01 Chevy Impala 9C1 police package "Unnamed yet". 154K
88 LX 5 speed "Silver PHOENIX" Currently being rebuilt inside and out. 400K
88 L 4 speed "Cherry Bomb" saved from the car crusher just in time. 186K
06 Ford F-150 Pickup Replacement for my 2001 Impala Cop Car that lunched its engine.
I would agree, except it was doing this the same way prior to changing the alternator.Originally posted by zoe60 View PostMaybe your new alternator is bad. Might take it back and try another. Had that happpen to me on an old '71 cutlass convertible once.http://www.cardomain.com/id/hawkdoc60
hawk, maybe it'd help to take a couple of pics of this area to help pinpoint.. worth a shot.
-Aspire brake swap COMPLETE!
Off the top of my head, I don't remember what it was. I'll look it up gain.Originally posted by Ogrestiva View PostHow many mm of deflection are you putting into the belt?
I was thinking of doing just that this evening.Originally posted by ejp2fast View Posthawk, maybe it'd help to take a couple of pics of this area to help pinpoint.. worth a shot.http://www.cardomain.com/id/hawkdoc60
If my memory serves me correctly It's supposed to be 9mm of deflection, but I could never get my hands in there to check. otherwise you start to wear down the bearings, which could cause the pulley to wobble or tilt, which could conceivably cause your bearings to wear faster.Last edited by Ogrestiva; 04-01-2009, 02:21 PM.89' Maroon and black Festiva LX with a sunroof. :alien:
I was thinking it was 10mm, but I'm not sure without looking again.http://www.cardomain.com/id/hawkdoc60
what about over tightening?
I don't believe so because I was making sure the belt had the deflection specified.Originally posted by ejp2fast View Postwhat about over tightening?http://www.cardomain.com/id/hawkdoc60
Here's a few photos.
This first one shows the rubber powder on the alternator as well as how far down in the pulley it is now when I apply pressure as a result of deteriorating on the way home.
This one shows how much slop there is in the belt as it was when I parked it at home. Also, you might be able to see the belt powder residue on the timing tab.
This is as the belt is just hanging with no interference by me.
Once again, the alternator did not come loose. The car ran wonderful after I replaced the alternator until last night. This problem has always started all of a sudden.
I don't know guys. This has me stumped.http://www.cardomain.com/id/hawkdoc60
I forgot to mention that I can go for 2-3 weeks with no issues and then it just suddenly starts acting up.http://www.cardomain.com/id/hawkdoc60
No on either.Originally posted by Ogrestiva View PostDoes it sequel after tightening? or when it rains?http://www.cardomain.com/id/hawkdoc60
