1989 ford festiva carbureted model. heater not working. the blower motor is going but no heat is coming inside the cab. any ideas? are heaters a problem with these cars?
WHATS UP WITH THE HEATER?
Remember that the heat will not come out the dash vents, only out of the floor and defogger.
matt
That's how it's designed. Wonder tho, if Festies without A/C are the same way?
1989 L - 247K miles Slick
Yep, non-A/C are the same way. One of the dumb little things about Festivas. I can't figure out why they would have done that. They mustn't use heaters in Korea.
Festivas don't have the greatest heaters. They do ok when it's not really cold, but if it's -40° you better bundle up! They take forever to warm up, and when it's real cold, the engine will never get to normal operating temps, even if you go on a several hour road trip.
In the winter I always cover up the radiator and the hole where the A/C condenser goes with cardboard and that helps quite a bit.
Originally posted by hellraiser6919i dont think thier routed to the vents. you could probbally mod it and put some hose in their so it comes out the vents.
I plan on blocking the floor vents (which I never use) and re-routing to the centre dash vents just in front of the flaps, using old vacuum cleaner hose. That way when I set it on floor, I will have some dash heat.I will NOT drive a minivan
