Australian Festiva fault codes
  • Australian Festiva fault codes
    Hi i have a 1997 wb Festiva ,i think the ignition sensor in the dist is faulty and would like to get the fault codes but none of the posts here seem to cover how to get them(yes i searched first)because the wiring on the diagnostic plug under the bonnet is different,sti isnt there ,its the same connector as in the trouble codes thread but not wired the same so i'm stuck ,the only scanners i've seen on ebay are 16 pin obd 11 type and i hav'nt seen an adapter to suit so any help would be greatly appreciated thanks in advance Matt.
