Next thing.. 6th picture... the lines pictured.... the first line from top to bottom in the picture...
1rst line: hard line that I can't be sure is factory or dealer installed system
2nd line: factory system hose from compressor to top fitting on Evaporator core. You won't be using this line for your setup.
3rd line: dealer system from top of Evaporator core to compressor. If I read the pictures correctly, you have this line installed in another picture.
4th line: factory system hose from Compressor to Condensor. Not for your system.
