Problem with engine Festiva L '88( carbureted )
  • Problem with engine Festiva L '88( carbureted )
    I have a new problem.
    When I turn on the engine everything is OK.
    When I try accelerate the engine turn off.
    I changed fuel filter and inspected fuel pump.
    Pump is good( I think).
    Sorry. My English is not good.
    Otaliko
    Check for fouled spark plugs., Intake manifold leak, or An EGR system malfuction. A lot of times a clogged PCV valve causes it to die at stoplights.
    I buy 'em dead........ getitqwik@hotmail.com
      I would also check the fusible links under hood, I think an 89' is by the battery area!!! Those that control the fan also control ignition area i believe. Then check fuse panel at dash for any bad fuses, I really doubt this area but....
