Having hard time finding size of crossmember bolts. Problem is I am missing one. Couldn't match at AutoZone, Ford couldn't give me size and said part is discontinued. Any help on determining size (diameter/thread count) appreciated, might be able to get it from McMaster Carr?
Crossmember Bolt?
I have some extra's..... do you need all 4 or just one?
Pm me if you need some. 17mm socket, don't know the thread, diameter
-Aspire brake swap COMPLETE!
I am missing one, another has really bad threads, so two would be ideal, one if that's all I can get. It would be a great help. Let me know cost/mailing. Just email me at jkilling@aol.com, subject "Festiva". Thanks
just sent you an email.Originally posted by jkilling View PostI am missing one, another has really bad threads, so two would be ideal, one if that's all I can get. It would be a great help. Let me know cost/mailing. Just email me at jkilling@aol.com, subject "Festiva". Thanks
I believe the front bolts are different than the rear ones...The Festiva Store
I have all 4, i'll see if they are different...
I used ordinary bolts of the correct size and length and used steel bushings to create the "step." I can't recall now where or from what I got the steel "clamp-up" bushings, but they have worked out fine on Rustiva for a couple years now. If you have access to a lathe bushings could be made real easy.
Yes, in fact they are. Fronts are shorter and have a "sleeve", and the rears are a little longer and regular bolts.Originally posted by nonamekid View PostI believe the front bolts are different than the rear ones...
