in the middle of replacing my crankshaft seal, how do i take off the crank timing sprocket? thanks
crank timing sproket removal?
yes you do. you can use a 13/16 wrench with it on the ground in 4th gear an parking break set. or pull the starter an stick a big screwdriver in the fly wheel teeth to hold it.newport tn
88 262,000 4spd hit in rear
91 224,000 5spd daily driver since 2000
91 81,000 5spd second owner
90 204,000 5spd
93 automatic rolled 25,000
Take the passengers motor mount undone drop the engine lower on that side and usr an impact on it.---------------------------------------------------
Originally posted by yblock View Postyes you do. you can use a 13/16 wrench with it on the ground in 4th gear an parking break set. or pull the starter an stick a big screwdriver in the fly wheel teeth to hold it.Originally posted by festivaWES View PostTake the passengers motor mount undone drop the engine lower on that side and usr an impact on it.
Worked well for me-Tim
93 Festy L- Little Red
98 Ranger- The golf ball
92 Accord- The $20 car (R.I.P)
73 F-100 (looking for a 302)
"Wait... you mean they pay people to fix their cars? Idiots..."
