Hi everyone,
Well, in addition to the front engine cradle mount coming off (and sitting on the sway bar),
Now it appears I have a broken trans mount. It hear that clunking noise when taking off from a stop, and also going into 2nd gear. Does not do it going into 3rd or 4th.
Anyhow, this is not good!
I have a friend who may be able to fabricate and weld some metal for the front cradle mount under the radiator, but how about that rear mount? I did a search and did not find the answers I was looking for.
1). I need a pic of the rear mount as it sits in the car, since I have no idea what it looks like, and my car is very greasy underneath.
2). Is it actually necessary to replace it? Will it do any harm if I don't fix it? (this is assuming I do get the cradle mount fixed)
3). How hard is it to do? If I have to support the engine in some way, and actually remove the cradle, it will not be possible for me to do it, and it seems like an expensive job to pay for. Keep in mind:
I have just a basic set of hand tools and wrenches here in CA, and thats it.
No engine hoist, etc to use.
No place to work on the car!
My car cannot be out of commission for longer than 2 days.
So, can this broken mount be welded back together or supported in some other way? I figure since he's under the car welding me up a new mount, why can't he weld this thing back together? My friend is a very experienced welder, and can literally weld anything.
It just has to last me a few more months, until I get back to PA (and I have that cross-country drive to worry me), and then I'll be getting a newer car. But it has to last 6 more months!!
If it sounds like I'm upset and worried, it's 'cause I am!
Thanks everyone for any help you can provide.
Mark
Mark
