Got a question and i think i already know the answer. On the 93GL i just got i think it has the timing belt screwed up on it. When you look at motor from front, the cylinders are 1-2-3-4. The firing order is 1-3-4-2. When you look at the distributor. Ok, when your looking at the distributor, you have two plug ins on top and two on the bottom. Ok, the two top ones are suppose to be 1-3 with the first one number one. Bottom two are 4-2 with 4 in back and 2 in front under number one. Ok, now, the way mine is is one is on the bottom in the front position. Two is on top in front position, 4 is on top in back position, and three is on bottom in back hole. so the firing order is 1-2-4-3 and one is not in hole it is suppose to be in. Im thinking when they put belt back on after they put head back on, they screwed it up, but believe it or not, it is actually running pretty good. Would this mess up anything being out of order when i go to get it emission checked. It starts right up, it shuts off when you turn key off. What do you think. I figured i would take it over and try and go thru emissions and see what happens. Here's another thing, i think valve guides in it are a little week. When i first start it up it smokes a little, then clears up. Apparently when they put new headgasket on, they milled head down so it was flat but didn't build head afraid it would then put pressure on rings and would later need the engine rebuilt. So, i put heaveir weight oil in it 20-50 and put bottle of bardahl stop smoke which is suppose to sort of seal around valve guides a little. I also sprayed bleach into the back tailpipe to get rid of the soot that has built up in there and it worked pretty good. My main concern is the way timing order is and position of number 1 plug wire.
__________________
thom
Lifes too short, dont blink. You only get one chance at it
1993 Festiva L-Cut inhalf and made a small truck out of it. When i need A/C, i fold back window down and open door windows.
93GL-Not going to cut this one. Gonna leave it looking like a Festiva(besides, wife threatened to cut me if I cut this one)
__________________
thom
