I have an orange Festy inter. wiper for my '88. Everything works when I installed it except the intermittent. Same way with a white one. Looking at the terminals and plug, there is 6 on the switch part and only 5 in the harness plug. Can't find anything from searching the forum about needing to add a wire to do this upgrade. Any suggestions?
Installing intermittent wiper
88L 328,000 winter daily driver
93L 167,000 summer daily driver (AC)
90LX 374,000 swap candidate
88LX black- parts
89LX burgundy-parts
91L red-parts
Someday my ship will come in. With my luck, I'll be at the airport. (aviation machinist)Tags: None
1989 Red L- The Baron
www.letstalkbeatles.com
Link to Baron Pics:
http://s478.photobucket.com/albums/r...nmervap/Baron/
1990 White GL- Chuck (for now)
Since I'm changing from an orange switch without intermittent to one with intermittent, what do I have to do to make the intermittent work?88L 328,000 winter daily driver
88LX black- parts
89LX burgundy-parts
91L red-parts
Mt. Airy.In Surry county. Andy Griffith's hometown.88L 328,000 winter daily driver
88LX black- parts
89LX burgundy-parts
91L red-parts
Easy swap....I believe that you are just trying to change the stalk.....but you need to change the control box that it is attached to also...here is a pic with the parts you need....Originally posted by Speedbird View PostSince I'm changing from an orange switch without intermittent to one with intermittent, what do I have to do to make the intermittent work?
I'm changing the whole thing. In the picture above, you can see the 6 terminals on the module. My wiring harness only has 5. It plugs up fine; but there's one wire missing.88L 328,000 winter daily driver
88LX black- parts
89LX burgundy-parts
91L red-parts
Nobody ever tried to put intermittent wipers on an 88?88L 328,000 winter daily driver
88LX black- parts
89LX burgundy-parts
91L red-parts
Mine was just plug and play. I don't remember the number of plug ins.1960 willys pickup
1967 jeep cj5
1988 festiva
1989 festiva
1990 festiva for parts
1991 s-10
Update
Apparently I have an early 88 model. I looked at my 88 parts car and it had all 6 wires in the harness plug. So I removed the terminal and a few inches of wire and installed it in the empty slot in the plug. Looked at the schematic in the Haynes manual and saw that it was supposed to have 12 volts. So I ran a hot wire from the fuse box. Works fine now.88L 328,000 winter daily driver
88LX black- parts
89LX burgundy-parts
91L red-parts
If your 88L doesn't have rear defrost, the wiring for power mirrors, int. wipers, defrost, and some other stuff isn't present. I believe this only was for the 88-89 models; 90+ had all the wiring even if your model was the bare bones one.
I had an '88 with the "simplified" interior wiring harness and couldn't get the int. wipers to work either.
-TimWhite '89L auto - Sold!
Silver '06 Rav4, 95k!
You're right. It's a bare bones 88L. I installed intermittent wipers and power mirrors on my 93L today and they work fine.88L 328,000 winter daily driver
88LX black- parts
89LX burgundy-parts
91L red-parts
Old thread I know... I am having the same situation on my '89. I got the arm and module and installed them, but no intermittent. I have the same 5 wire plug that should be a 6 wire plug for the new module. Has anyone else figured this out? Can I just stick a jumper wire from one pin to another? Thanks in advance.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
Read the last sentece for his solution.Originally posted by Speedbird View PostApparently I have an early 88 model. I looked at my 88 parts car and it had all 6 wires in the harness plug. So I removed the terminal and a few inches of wire and installed it in the empty slot in the plug. Looked at the schematic in the Haynes manual and saw that it was supposed to have 12 volts. So I ran a hot wire from the fuse box. Works fine now.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I was just wondering if there was another hot going into the switch already that I could just jump off of. Also, he didn't say whether it was 12v switched or constant.Originally posted by TominMO View PostRead the last sentece for his solution.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
