where are the horns mounted
  • where are the horns mounted
    I had a horn fault and ended up buying a new horn and tapping into the horn feed at the relay, I still am interested because I had a good look and they don't show up my Gregories manual. and yes I blew a few fuses diagnosing the fault
    thanks all :p:p:p:p
    "all I ask is the chance to prove that money won't make me happy":simon:
    passenger side front bumper...i think LX's have dual horns??
      The horn is mounted inside a cavity near the passenger side front corner. It's hidden. I don't know if you have to remove the bumper cover but I suspect that would make it easier.
      Check out some pics from the Festiva Madness 2 meet in Raleigh, NC. There was a parts car there at the meet and once everyone took parts off of it, then you could see the horn.
      www.cardomain.com/id/jermnc77
      Madness Committee Member & Contact Person
      www.festivamadness.com
      Festiva Madness
      Snoopy's
      4621 Atlantic Ave
      Raleigh, NC 27604
        It can be removed without removing the bumper. I did it two weeks ago.
        1960 willys pickup
        1967 jeep cj5
        1988 festiva
        1989 festiva
        1990 festiva for parts
        1991 s-10
        "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!" —Benjamin Franklin, 1759
          An LX or GL will have dual horns, one on each side.
          93 GL modyfied!!!
          :fish:
            PF inside the bumber no need to remove anything to get to it... put a larger mazda b3000 horn in mine now you can be afraid... or move the heck outta the way.
            "There's no half singing in the shower, your either a rockstar or an opera diva"
            88' L (Daily Driver) 88' LX EMERGENSTEVIA
              They are prone to rust where they are installed at the factory. I pulled the wire back into the engine compartment and mounted a louder horn in one of the unsued threaded holes on the fender.
                Would that be the same on a RHD Festiva?
                2005 Mitsubishi Lancer Ralliart
                1991 Ford Festiva LX
                1989 Mazda 323 GT
                  Thank you all for solving the mystery
                    I don't mean to argue, but are you sure the GL's had dual horns? My 91 GL is single. (Unless the drivers side was removed by somebody previous to me)
                    Can anybody else with a GL confirm this??
                    the 91-93 in this chart has ???????? listed.
                    ha! ask ketchup!
                    -Aspire brake swap COMPLETE!
                      ^^I'll look later on today.
                      93 GL modyfied!!!
                      :fish:
                        sorry i thought you said RWD, not RHD...
                        i'd think RHD would be the same as LHD.
                          lol, It happens.
                          1989 Mazda 323 GT
