plywood jig for axle nut removal
  • plywood jig for axle nut removal
    The following web page is a description of a simple plywood jig for removing stubborn axle nuts, plus a couple of photos...
    Web hosting and free web hosting from Bravenet.com. Build your website with our easy webpage builder, web tools, web services, and free website content.
    They're really not that hard to remove. The rear bottom shock bolts (providing the car is from the rustbelt) are much harder to remove.
      Wow! That's pretty excessive...If I had to use a bar that long...i'd be scared that something important would break.
      Joe Lutz
      The SKATE ..... 1992L 5spd
        Excessive is an understatement! I'm sure that there isn't an axle nut on earth that couldn't be removed with that setup!
          Why would you need something that excessive for!?! Snapping the axle in 2?
          - Unknown
          - Quentin Crisp
          - Bumper Sticker
            Well at least it's OSB, I think that would give on first...haha Who put your axle nuts on? That wouldn't remove the lug nuts on my Integra after this guy did a crappy rebuild on my engine...what an idiot that guy turned out to be...
              The wheels are off a junked car. As it says in the writeup the impact wrench I borrowed from an auto parts store didn't work. It just spun. The store manager suggested an extension pipe. All I had was the handle bar of a mountain bike which I had already tried, and the stand shown in the photos. However, the point of my posting was using the plywood as a way of holding the wheel steady while applying the force from the pipe. It also says I got the wheels last summer and tried different ways of getting the axle nuts to turn, braking a bench vice in the process. I tried everything suggested in this forum back then. If nothing else works, try it. It worked for me. I din't find it a bit excessive. Just right.
