Is there only 2 wires on the inertia switch? And can it be bypassed to a hidden kill switch? Thanks
Inertia switch?
I have a car with the wires tied together. No inertia switch. The car runs this way.Originally posted by drof 89 View PostIs there only 2 wires on the inertia switch? And can it be bypassed to a hidden kill switch? Thanks
I don't know why you couldn't interupt that circuit with a toggle switch. You could do the same with your coil feed.
I dont' see any reason why you couldn't do that. It is meant as a "safety" feature but who needs those!! As long as the wires make a complete circuit you are in business!!
Originally posted by Biglay5150 View PostYea and if you roll over or get rearended and your car pumps fuel every where and catched fire it wont really matter anyway.
If you interupt the ciruit with a toggle switch, leaving the inertia switch in place, the car still won't run unless the toggle switch is closed.
