Can you swap into a Festiva the Aspire engine/trans as a unit, and then use the Festy CV axles? I understand the only difference between the Aspire trans and the Festy trans is internal gearing.
Aspire trans with Festy cv axles
Tags: None
yes.. the final drive is different, but they are both e-series trans.
See this stickyLast edited by ejp2fast; 05-20-2009, 01:30 PM.
-Aspire brake swap COMPLETE!
Thanks!Originally posted by ejp2fast View Postyes.. the final drive is different, but they are both e-series trans.
See this sticky90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
