Could a very badly leaking exhaust manifold (nickel-sized hole in the manifold and a bad connection to the downpipe) give false readings to the O2 sensor and make the car run poorly?
Quick O2 sensor question
Hole in the manifold ? Does it have hair line cracks all around it like a spider web?
I have only seen a couple manifolds burned out, mostly big stuff thats under load all the time. If you burned up a manifold you have problems, more then just an O2 sensor.money pit
No spitters were I work, you swallow it all. The Company feels if you already have it in your mouth why waste it.
