I have a '90 Ford Festiva, stock 1.3L engine, fuel injected, about 150K miles. The car has been running great until . . . .
Did routine oil / filter change recently, but did not run the engine when finished the job. Then, went out of town for a week. Home again, cranked the car. It started and ran for about 5 seconds then quit. Would not restart, just cranks over and over and over.
Checked the following:
All 4 plugs have good healthy spark.
Fuel pressure is about 50 psi just before the fuel rail.
Noid light test shows that injectors are getting electrical signal.
Disconnected air intake from air flow sensor box and sprayed starter fluid directly into intake while cranking. No sign of starting.
Compression check showed 125 psi for all 4 cylinders. Very low, but consistent for all 4. With engine at TDC, found that timing belt was off 2 teeth on the cam drive pulley. It seems that the belt had slipped, even though the tensioner was tight????
I removed the timing belt and inspected. Looks great (was changed about 15K miles back). I put the timing belt back on correctly, and verified that distributor is pointing to #1. Still no start. Rechecked compression -- still at 125 psi, consistent for all 4.
Performed leak down test. Got readings of 0 - 5% for cylinders 1, 2, 3, and about 40% for cylinder 4. It sounds like air escaping into exhaust for cylinders 1, 2, 3, and into the intake for #4.
1) If the timing belt slipped 2 teeth, as it seems, would that likely result in valves hitting pistons? I don't recall hearing any noise as such, and still don't hear any weird noises when turning over the engine.
2) Would the timing belt slip be caused by not starting the engine after changing oil? I'm thinking that maybe the valve train was dry, and the oil pump needed to fill the filter before the oil pressure came up to lube the top end, and maybe the friction was enough to make the belt slip.
3) Anything else I should check before tearing into the engine to look for bent valves?
Thanks in advance for your help.
Alvon
Alvon
