i Have a 1989 festiva carb and the gas gauge does not read properly. I need the fuel sending unit along with the floater. Does any know where i can get a new oem, used replacement or a work around with a universal unit from the auto parts store.
fuel sending unit
If the seafoam doesn't clear it up, I'd try a junkyard. I think you can get them oem from Ford, but they are kind of pricey. Or, check this out.
1989 L - 247K miles Slick
most likely, you've rubbed through the resistor coil wires in the sender (i've had 3 like this). pull it out and replace. i'm currently working on a fix for this but it may be a while yet.Trees aren't kind to me...
