93L Bench tested the alt got 14.7v 53amps
New batt.
New batt terms, new head and main links, new engine and meters fuses.
Good continutiy(sp?) from b+ lead off the alt to the batt(white wire)
Good continuity to ground.
With the ign in the run position I get 11.2v at the L term on the alt plug.
My charge indicator light does NOT light with the key in the on position engine off. Could this cause my low voltage problem?
I just did a search and every time it seems to be the belt. Mine is new, but I hemorage oil so it looks like poo. I'm gonna swap a new belt in at lunch and try again. Any other suggestions are still very welcome.
I'm gonna feel like a dope if its the belt.....
New batt.
