Transmission fluid milky
  • Transmission fluid milky
    Hello,
    I have put a couple hundred miles on my newish transmission I got from Festyboy, and I went and checked the level today.
    It has become sort of milky in color, still red, with a bit of a Strawberry Nesquick look going on. This is a manual transmission so there is no antifreeze getting into. Does anyone have any idea why it would be milky?
    The transmission was sitting outside when I bought it, and I am guessing maybe there was a little bit of water in it when I installed it. That is the only thing I can think of.
    Logan
    That may be the problem. Id flush it and put fresh fluid in and see if that takes care of it.
    - Unknown
    - Quentin Crisp
    - Bumper Sticker
      Maybe you put Strawberry Nesquik in by mistake?
      Seriously, take MONSOON's advice.
        yup thats what i would say too, drain and start with fresh, see what happens
          Improper fluid level. Try like they said, drain and refill to proper level.
          93 GL modyfied!!!
          :fish:
            Why would improper level cause it to be milky? I will drain and refil it though. I followed the haynes manual and put the exact amount in, is the book correct?
            Following the little mark on the speedo is hard to really tell
              I would think if the level were too low it would allow condesation to somehow build up inside the case.
              - Unknown
              - Quentin Crisp
              - Bumper Sticker
                too high and it will aerate (get millions of super tiny bubbles in it), but I think its water contamination. Drain and refill.
                Jim DeAngelis
                kittens give Morbo gas!!
                  Cool bit of information to know though, thanks guys!
