My Festiva has been racked in the garage for the past week.
New:
Axles...rotors....drums....front & back wheel bearings...calipers...drum cylinders...brake hardware...wheel seals...mtx seals...master cylinder...rear shoes...front pads.
Anyway....I can not get the the left front and right rear brake circuits to bleed well. Some times a squirt...sometimes a drip. Both are fed thru the secondary cylinder on the M/C....lower half of the proportioning valve.
I've hooked up primers to the output of the porportioning valve for both the problem brakes and there is no air between the M/C and output of the prop valve.
I've inspected all the lines....no leaks.
Any ideas?
New:
Any ideas?
2009 Festiva Madness link with pictures. 51 Festivas & 4 Aspires from eight states attended.
