Hi guys,
Guessing this is something electrical between the ignition and the starter, maybe a loose wire or who knows, but I want to see if you might have any ideas. I've been doing some long (and fast) driving over the past few days, no problems at all on the road or when starting the car. It truly runs great. Today, I stopped at a gas station to fill up, and when I went to start again, I moved the key to ON... headlights, radio, everything worked... except when I turned it to start, there was nothing. No noise, nothing, just silence. You know how when you turn the key to ON, some of the lights on the dash come on as a test? When I turned the key to start, the Brake light came on, and would go out when I released the key back to ON. So clearly, the car knew I was putting the key to Start, as that test LED responded.
Well, after some poking around under the hood (but first, putting the car into neutral and pushing it away from the gas pump so others could fuel up... LOL), I was able to jump the starter with a screwdriver and it started up just fine. Made sure not to turn it off until I got to my final destination, some 40 or 50 miles of further fast driving away...
Then... I park the car, turn it off... and just for kicks, went to start it again with the key... and it fires right up.
Any ideas? Seems like the ignition switch is fine, the starter is fine, and the battery is fine. I'm not the most mechanically inclined, but if I'm told what to look for, I can do it. This is a '92, automatic. Thanks!
