As long as I’ve had my car the “check engine” light will randomly turn on and off when the temp needle just starts to move, and eventually stay off when the engine reaches operating temperature. It won’t turn on again until the engine has cooled off.
This doesn’t affect drivability or gas mileage, but when the car is in Park and the CEL comes on, the car does some odd things. When the light is on, the idle will go up by a few hundred RPM, and when it turns off the idle will dip very low, and the engine will sometimes die. When the engine dies, it’s hard to start again and I have to push the pedal to the floor to get it going. It will sputter to life, and won’t cause any more problems until the engine cools off again.
I’m guessing that the coolant temperature sensor is the cause, but I lack even the most basic diagnostic equipment so I can’t read engine codes or get resistance/voltage readings. Since the “shotgun” diagnostic approach is kind of expensive, can anyone narrow down my problem from the symptoms? I’d be eternally grateful to whoever can point me in the right direction.
The car is an ’89 Auto with the oddball EFI.
Thanks!
Tim
Thanks!
Tim
