Aspire Brake swap, brake line question.
  • Aspire Brake swap, brake line question.
    I noticed that the place I got the trailing axle from snipped the brake line right about where the e-brake cable connects to the 2nd cable on the axle. is this going to be a problem, or will I be able to get away with patching it into the fes' brake line with a FtoF tube connector & 2 small hose clamps?
    "Nothing's gonna grieve us
    When we drive Festivas
    I could go a hundred miles an hour
    Long as I got the Almighty Power
    With my plastic Jesus
    Riding on the dashboard of my car"
    to save problems down the road, replace both brake (rubber) lines with new ones and if the metal lines were snipped, replace them with new metric lines too.
    THERE IS NO QUICK FIX WHEN DEALING WITH BRAKE (FLUID) LINES, THE PRESSURE INSIDE FAR EXCEEDS WHAT HOSE CLAMPS ARE DESIGNED FOR!!!!!!!!!!!!!!!!!1
