When the lights are on or a large electrical load is placed on the alternator, the idle RPMs go up to about 1500.
However, when I am using the A/C the idle will stay at 800 RPMs even when the lights are on. This probably isn't good for the car.
Is there a way to adjust the idle to compensate for this? It's hard to explain, but when the A/C is on, another solenoid keeps the engine at 800 rpms, and if I were to adjust the idle up valve thingy on the throttlebody, it would screw up the settings for idling up without the load of the A/C.
Is there an auxillary idle up for electrical loads when the A/C is on?
Does any of this make sense?
Regards,
Tim
Regards,
Tim
