ok so heres the story, bought the car from a member here on the board and trailered it home. It sat for the last month or two with the engine pulled and now i decided to daily drive it. here is the problem, I changed the plugs, wire, air filter today and re-installed the eninge. it fired up on the second try but then when i took my foot of the gas the car started to drop idle quickly. I gave it gas thinking the lines might need to be purged (drained the tank and put fuel stabilizer in it for the storage purposes), it revs fines with no hesitation but when i let off the gas it started to drop again. so this time i let it go down to see if the idle was just set low on it. The car started shaking terribly as the idle dropped, so bad my dog finally got out of it. I thought maybe i had the plug wires wrong but i believe they are correct.
I have searched the board and i havent seen anything quite like this. some stuff was similar, but not the same.
the only thing i notice that looks odd to me ( cant find my repair manual) the intake looks like there is a vacuum hose missing. there is one nipple on the side that doesnt have anything running to it. it is a smaller nipple all the way in the back by the firewall.
the car is a 89 fuel injected
p.s. its gettig spark and gas obviously, dont think its the timing b/c wouldnt it stumble all the time
