Radiator Hoses and Lines
  • Radiator Hoses and Lines
    So I successfully replaced my radiator fan and the new aftermarket fan works great! But.....during the installation the overly rusted trans cooler lines that run along the bottom of the radiator started to leak as well as one of the rubber hoses. This is expected since it looks like these are original lines. So where can I get a new set of lines both the metal and rubber that have the proper bends? One of the rubber hoses makes a tight 180 turn and if I am not mistaken on one of the postings here it was stated that you can't get them anymore.
    Yes I am a little green about this..just need to know if my hunches are right.
    For the metal portions do I just go to a Mcparts and order them and they will come with the proper bends? Same for the rubber?
    You should be able to get all that at your local parts store. The lines will be straight, you'll haveto bend them for your application.
    93 GL modyfied!!!
    :fish:
      Yeah i get all my hoses from Autozone. I had to replace all of my coolant lines when i did my engine rebuild/swap. I grabbed like 500 diffrent hoses and then took them home and eventually made it work.
      "There's no half singing in the shower, your either a rockstar or an opera diva"
      88' L (Daily Driver) 88' LX EMERGENSTEVIA
