Newbie needs help re: headlights
  • Newbie needs help re: headlights
    Hey what's up? I'm a newbie here. Actually, I've been lurking around for a little while. I write to you today because I have a concern regarding the headlights on my '89 Festiva L.
    I did a search on "headlights" in this forum, and honestly I'm not sure if the answer I need is in any of those posts because I'm a dummy when it comes to cars and I don't understand all of the terms used. I don't have the owner's manual or the Haynes Repair Manual, but I plan to order a used one from Amazon today (it was the cheapest I could find.)
    My problem is the headlight on the passenger side is out (high beam as well.) I thought it just needed to be replaced, so I bought and replaced both lights, but the same one still isn't working. I first noticed the light was out on a night when I was having problems starting the car. To make a long story short, I was trying to replace the dome light, but it didn't work, and the next thing I knew, I couldn't get the car to start (it would turn but wouldn't catch.) Turns out the distributor needed to be replaced, which I just recently had done, but the headlight is still out.
    Is it possible that trying to replace the dome light may have caused a fuse to blow out? The taillights seem to be working fine. Are any of the fuses below the steering wheel for the headlights? I did not see a slot that indicated as such. Should I be looking elsewhere? Thank you in advance for the help!
    the fuse for your lights would control both not just one. You may have a broken wire running to that headlight, try tracing the wires. There is also a relay that controls the lights.
      Thanks GForce. I went to Pep Boys yesterday and had someone take a look at it (actually it was the same guy that helped me last time, when I couldn't get my car to start.) I guess the light wasn't connected properly because he pushed it in and it worked. I'm glad that it wasn't serious, and that he didn't charge me. But I feel kinda stupid because I thought I connected the bulb properly. Oh well....both headlights work now and that's all that matters. Thanks again for the help!
        ^^Sweet, glad it was something simple.
        1988 L - 232K miles Batstiva
        1989 L - 247K miles Slick
          Don't feel too badly... you're not the first one to have that happen! LOL!
          Focustiva: Because I was told it was was impossible to fit a Focus bumper on a Festiva.
          In memory of Dean Allen - V8 Festiva 1955-2010
