Ho do you remove the steering column?
steering column
bolts and screws, disconnect the wiring harness. There should only be 2 or so 12-14mm bolts holding it to the dash brace or the firewall. Take out the one bolt in the steering joint at the firewall, and discount the harness from it. Cake.---------------------------------------------------
i take it the dash doesn't need to be removed?Last edited by ejp2fast; 09-29-2009, 09:47 AM.
-Aspire brake swap COMPLETE!
Nope. There is a litte more than just the steering collumn. There is about 6 bolts, and 6 or so wire connectors to disconnect.Last edited by festivaWES; 09-29-2009, 07:51 PM.---------------------------------------------------
