idle air control
  • idle air control
    idle air control sensor i need to know how to remove it from the tb with out breaking it. i cant get one off. thanks
    also i have to hold the flap in the maf to get the car to start and stay running and if i open the flap and rev it the car does fine??
      try to unplug it and see if it will idle.
      -Greg
      Redneck Engineer
      FOTY - '09
        it wont even start unless it is help open haha il try it
          yeah i tried it. the car stays running for a few seconds and thats it what does that mean?
            idle air control, is not even located on the throttle body its a part of the intake manifold by the fuel filter/brake booster.
            Furthermore a festiva won't run with the VAF unplugged. If you have access to another VAF I'd swap it out. Try changing the O2 sensor, and fuel filter. Maybe you have a clogged injector or two.
              then whats the other sensor on the tb? and i am borrowing one from matt tomarra
                I agree....could also be slight timing problem or crudded rotor/cap or other ignititon component.
                Joe Lutz
                The SKATE ..... 1992L 5spd
                  BE sure to let them know that you're asking questions on the BP not a B3. The idle speed controller in on the throttle body on the BP and I've never removed one.
                    yeah my bad i keep forgetting that i have a bp in mine. ok and i have not tried your vaf yet will in the morning. the car is in time had it checked brand new fuel filter injectors are clean had them cleaned by my dad. new cap rotor and wires and plugs. the car only runs if the vaf flap is open like i used a pare of side cuts in it to keep it open to get it to start and stay running so i could get it out of the shop
                      yeah matt that vaf didnt fix any thing haha
                      i got my old harness out and was tracein wires and seen some weird stuff. like the white wire that is the single wire i think for the vaf is like coated in another wire that is black and i traced it and it splits off and the black wire thing turns into a ground and gos into a plug that is nothing but grounds and then all the grounds go to all the other stuff that has grounds and were they ground to the body and so on. also there is a blue wire that does the same thing but goes to something and i dont know what haha but it was blue and does the same stuff as the white one. would any one know what might this like before like why they are coated in the black and go to ground and to the ecu?
