Ok, it's hot enough in here Boise, ID so I'm adding AC to my non-AC '90, EFI engine. I've ran into the crankshaft pulley mismatch problem. The goal is to have the stock, inner pulley (alternator to water pump to inner crankshaft), and add the outer pulley (compressor to tensioner to outer crankshaft). My original single crankshaft pulley is the "square-notch" type. The junk yard crankshaft and AC pulleys I've found have an alignment hole instead of the notch. I'm guessing the junkyard pulleys are from a '93 (the odd year)? I've also seen some photos here of a third, "egg"-shaped pulley.
Can someone write up a summary of crankshaft and AC pulley types and the years/engines they work with? Hopefully this will help people know what to look for when at the junk yard and save a few trips.
