I've been having problems with the carburetor for awhile now. It would run rough sometimes, idle up & down, run poorly until warmed up, etc. A month ago the thermostat stuck & the temp gauge went up just under the Hot line. I left it cool down, got it home, and changed the thermostat, etc. All seemed back to normal - ran the same & not getting hot. I finally fixed the carb & now it idles nice, seems to rev fine, etc. When I drive it though it seems very sluggish & won't rev under load. It occassionally bucks & wants to shut off too. I am getting 5 psi out of the fuel pump (as I should be), plugs, wires, etc are all good. Carb vacuum lines are all on correctly & have no apparent leaks. Ignition timing is correct. When I was playing with the carb & had the car idling for an hour or so, the fan relay kept clicking in & out & in & out (which kept turning the fan on & off). I pushed on the plugs at the firewall & the fan problem stopped. The temp gauge was fine but the coolant in the overflow bottle boiled & overflowed.
Given how the car runs poorly under load... could it now have a head or head gasket problem even though it never got really hot? How can I be sure? It has 145,000 miles on it.
