sorry not festiva related but getting frustrated over here with winter arround the corner dont want to spend another one relying on my dashboard mounted heater and blowing my breathe out the right side of my mouth to keep the windows from fogging lol.
problem is the blower motor only works on the high setting, and in the high setting it works as if its on the low setting. So I get a very low flow of hot air out of the Defroster vent, and no other vents work at all. This problem also occurs with the A/C.
so far ive replaced
all the maxi fuses in the maxi fuse relay
the relay switch under the hood
some relay switch under the dash, that belongs to the heating system
2 used blower motors, both have same problem
checked/replaced all the fuses under the dash and on the drivers side panel.
this is a 1991 delta 88 royale oldsmobile
so far ive replaced
