So...my new 89' LX. Its a nice car and everything...but it had its issues. And theyre really giving me a pickle!!! There is a leak in my break lines somewhere. It seems to be leaking from somewhere inside the break fluid distrobution block. You can see it really dripping out from the crossmember, just below the distribution block. Its really leaking from the crossmember. But I can't really seem to tell if its leaking from the distrobution block or maybe one of my rear brake lines inside the crossmember. To change those brake lines...will I have to remove the crossmember or what all do I have to get my breaks running again? I've been considering getting some brass FPT (flare pipe thread...what the break lines use) plugs and just plugging the rear ones...or maybe just one of the rear ones to see which one is the culprit and attempt to run on just 2 or 3 brakes
. Its not Ideal...but...starting august 18th I wont be driving it anyway because I'm leaving it here when I go up to college in ames. But I reallly reallly want to fix it before I leave. So any help or advise will be appreciated.
