question on pulling engine & tranny
  • question on pulling engine & tranny
    did a search - did not find an answer to:
    on a '91 festy i am pulling the engine & tranny as a unit.
    the official ford manual says to remove the engine/tranny cradle (i.e. "crossmember") - do i really need to do that?
    can't i just undo the engine mount bolts, lift the engine/tranny and leave the cradle in place?
    (i'd rather not remove the cradle, as the front 2 bolts are pretty rusted.)
    Thats what I did. I had the same problem with the bolts being rusted on the radiator support and 2 rear bolts. The nuts that are welded in the floor board broke loose and had to cut a hole in the drivers side floor pan. You should fix the radiator support due to it being a weak point.
    DV8 1 :twisted:
    MAZDA MAZDA MAZDA MAZDA MAZDA MAZDA MAZDA
    2003 Protege5
    1983 Rx-7 Limited Edition
    1991 Festiva (soon to be a 121)
    1991 Chevy S10 pickup (R.I.P.)
    1990 Chevy S10 pickup Bagged on all 4 corners
      I just did 2 swaps and did not remove the cradle on either.
        if you LIFT the engine/tranny, then the crossmember doesn't need to come out...
        if you DROP it out, you obviously do.
        -Aspire brake swap COMPLETE!
