Where is the "Fan control module" located?
  • Where is the "Fan control module" located?
    -Fred
    -93' L BP swap/e-series, coilovers, RIO front swap, redrilled festy drums, Miata 14" 7 spokes.
    -85' Nissan Sentra 5 spd.
    Are you talking about the relay for thr radiator fan??
      Yes, do you the location of the relay or the thermal switch?
        There's a relay on the thermal switch ? Its up by the battery, between the battery and the headlight, has a cover over it. Not sure its thats what you mean by fan control module.
