i was wondering what turbo set can fit in my festiva? can i use a t3t4 turbo set? or who ever done the b3t setup what turbo set did you use and what is it called
what turbo set can fit to use on my b3 stock festiva?
I use a tdo4 it came off a first gen eclipse auto. Nothing just fits though. All has to be made to fit.-Greg
Redneck Engineer
FOTY - '09
Last week it was a honda motor now a turbo b3. Big block ford next week?
As far as turbo's there's only beed a few here who used the b3 so you might not see too many answers on this.
I ran 10 psi on mine. It ran great. Just pull alot of timing out of it. My motor also had 220k miles on it. I got the car to run a 15.8 in the 1/4 @ 84mph. Well worth it in my opinion. The b3 is a great motor. I also got over 40 mpgs with that setup. Now I have swapped in a b8 16v sohc. And it runs low 14s.Originally posted by 1993 festiva View Postis it worth it and does it run and how much psi should i use?-Greg
Redneck Engineer
FOTY - '09
May I suggest the following links:Originally posted by 1993 festiva View Posti was wondering what turbo set can fit in my festiva? can i use a t3t4 turbo set? or who ever done the b3t setup what turbo set did you use and what is it called
Now how can we help repair your vehicle?-Caleb
Originally posted by cracked.com on the M203 w/ M433 HEDPSo, for about the same price as a fully-loaded 1993 Ford Festiva, you could also wield the power to obliterate a small village in the blink of an eye.
