Get the car properly tuned up--plugs, wires, cap & rotor, air filter
Change the oil and filter; clean out the motor with Sea Foam before doing so
Retard the ignition timing a little
Stick a bottle of "Guaranteed to Pass" in the gas tank
Install a new oxygen sensor
Install a good aftermarket 45,000 volt coil (I recommend the Jegs generic coil, part #555-40105, with mounting bracket #555-40190) and gap the plugs 10% greater than stock. Index the plugs so that the gap is facing more or less at the intake valve. I get 7-10% better MPG from doing this, so it probably also translates into cleaner burning. It would be interesting to test this.
Readers please add on other ideas.
