5 speed trans noise
  • 5 speed trans noise
    I have a 90 festy 5 spd I need a trans or need help with a trans that will swap out with stock tranny with no mods ,this one growls all the time even with the clutch out ,tranny shop says the bearing on the main shaft ,the ring broke and all the balls have fell and the shaft is walking ,not really sure also need info on what clutch to buy and where available I am in central Illinois thank you for all info supplied and replied to. Doug
    HD2500 Duramax Chevy
    Z28 LS1 power 500 +
