So I pulled my engine & trans due to a wasted clutch & a bad head gasket. I got the warped head resurfaced and the valves reseated & new valve seals put on it. My question is what else should I do to the engine & trans while it is out to save myself problems down the road?
So far I have:
Clutch Kit
Trans input seal
Trans output seals
Front & Rear Main Seals
Oil Pan seal
Head gasket kit (Head, exhaust, intake, valve cover, timing cover)
Timing belt
Water pump
Is there anything else I should inspect or replace on the engine while it is out? Trying to keep the costs of the beater down, but don't want to spend all of the cold winter fixing it on the weekends. Should I get the flywheel resurfaced?
So far I have:
Clutch Kit
Trans input seal
Trans output seals
Oil Pan seal
Timing belt
Water pump
