if anyone lives around the philly area who can help me out with wheel bearings i would very much appreciate it .... please give me a call 484-643-2831 name is reed
anyone near philly help!
are you doing fronts, rears or both?
-Aspire brake swap COMPLETE!
just curious, do you have a haynes manual?
i've done rears, and they are really not too bad...
haven't done the fronts, but i think its a litte more in depth and the bearing needs pressed out of the knuckle.. someone else will have to chime in about that.
good luck, and hope someone can help you out.
if not, we can walk you through the process. oh, and here are few links FYI:
thread 1
thread 2Last edited by ejp2fast; 08-28-2009, 08:57 AM.
yes the fronts do have to be pressed out.1973 Cb750 haven't touched it yet with no idea what I am planning on doing with it
1978 25th Anniversary edition Corvette
1983 Chevy Elcamino
1993 Ford Festiva GL
2003 Hyundia Santa Fe ( Wifes Daily driver)
some old dodge motorhome I have no idea of the year
hear is some good info for you...
problem solved... :toothy7:Trees aren't kind to me...
You bought him a press?Originally posted by FestYboy View Postproblem solved... :toothy7:
he wishes... naw, i put it back together for him at the shop. i was surprised at how far he got without any "special" tools.Trees aren't kind to me...
Hell, getting apart isn't the problem!
Good ol side hammer will do!
Getting back together without a press and not destroying the bears now that's impressive!'93 Blue 5spd 230K(down for clutch and overall maintanence)
