Thanks to the many great posts on this site I was able to read my engine codes for the first time, worked great! Got a 15 (O2 sensor ordered) and a 17 feedback. What is the feedback code all about? How do I correct this issue?
Engine Code 17
could be a sticky injector making a rich/lean condition.. also look for intake air leak.
run some seafoam through the engine... and a little in the gas tank for the injectors.
do that before you put your new O2 sensor in.
-Aspire brake swap COMPLETE!
