This is my first post. I've been lurking and reading here for the past 6 months. Here's the history:
1990 Festiva LX, EFI, Auto, 118,000 miles.
Sitting since 1996 in garage.
Found burned exhaust valve #4 cylinder.
Replaced all valves,timing belt,water pump,gaskets etc....
Starts and idles fine.
Smokes from the exhaust(sometimes full throttle,partial throttle,letting off throttle)
Lacks power up until engine hits 3800 RPM, 1st or 2nd gear. Engine slowly surges but does not have power until magic number is hit on the tach.
Replaced coolant temp sensor, checked vane airflow sensor + inlet air temp sensor. TPS sensor switches are working.Checked ditributor for crud in the crank position sensor, checked compression 140 psi-150 psi,checked fuel pressure and regulator at fuel rail.
It runs very good with oxygen sensor unplugged. New oxygen sensor installed, no change in performance. Still runs like crap with it hooked up.
