Sti connector location. Can't find the one.
  • Sti connector location. Can't find the one.
    I have 3 connectors. But the one with the black and yellow wire is in the 6 pin plug. Could it be the STI? See attachments. I have timed the engine with the timing light without grounding the sti connector because I can't find it? What is the difference of grounding the sti connector?
    :festiva: 1995 Kia Pride, 1.3 EFI, manual. :fred:
    i found it useing search .... but here you go
    1973 Cb750 haven't touched it yet with no idea what I am planning on doing with it
    1978 25th Anniversary edition Corvette
    1983 Chevy Elcamino
    1993 Ford Festiva GL
    2003 Hyundia Santa Fe ( Wifes Daily driver)
    some old dodge motorhome I have no idea of the year
      that's not it. The only single plug connector that I have is not black but a normal transparent colour. The wire from it is yellow & green. Does anyone have the haynes manual and post some pic of it?
        year? Make? Model?
        1983 Chevy Elcamino
          I have a question for someone that have used the sti connector to time the engine. When you ground the sti, does the timing advance a little bit automatically? Pls answer
          Thanks
