need help with radiator fan
  • need help with radiator fan
    my father n law had it hooked up straight to the battery but id like to get it back to normal which wires do i need to check dont know too much about cars
    what year and model is your car? on the drivers side of the radiator at the top, is a quick disconnect from the rad fan to the engine wiring harness... unless its been removed, that would be where you hook it in.
    now, your cooling fan switch may be bad which is why your father in law hooked it straight to the battery....
    here is where that is:
    follow the top radiator hose to the engine.... at that point you'll see this single wire connector that is screwed into the thermostat housing.... thats it.
    -Aspire brake swap COMPLETE!
      thanks
      i found it thanks
