My Lil Runt (1990 fuel injected Standard 5 Speed) is throwing a tantrum and I can't figure it out.
Diagnosis;
Only starts 10% or less of the time.
Runs great once it starts.
Turns over and over and over and pops once in awhile like it's going to start just doesn't catch.
If it does catch at a low idle gas kills it immediatly.
If it catches and idles up and runs it runs great. You can cruise down the road at 65 no issues.
What I've done; (not all related to this issue but listed regardless FYI)
Recently new fuel pump
Recently new fuel filter
Recently new plugs, they look fine I pulled them.
New coolant temperature sensor
Recently changed out the fuel tank due to a leak but it was acting up prior to the tank change.
Going to try tonight;
Pull the battery and reset the computer.
Spray Starting Fluid in while turning over to see if it fires.
Any and all suggestions or questions to help me diagnose the Lill Bugger would be greatly appreciated.
Thanks, Cory
Diagnosis;
Thanks, Cory
