I'd like to replace the inner and outer tie rods in my 1989 Festiva. This link on eBay seems to be the best deal, but it's listed as 90-93? Is there a difference between the 88-80 and 90-93 tie rods? Will these work, or should I look elsewhere.
Inner & Outer Tie Rod Compatibility?
A quick check of AdvanceAuto's website shows the parts numbers are the same for 88L and 93L. Both for inners and outers. I think you'll be okay with those.
1989 L - 247K miles Slick
I was just at AdvancedAuto todayOriginally posted by batstiva View PostA quick check of AdvanceAuto's website shows the parts numbers are the same for 88L and 93L. Both for inners and outers. I think you'll be okay with those.
Spent $187.10 for pads, rotors, shoes, drums, and hardware kit. Declined on the tie rods because they were too expensive and figured I could get a much better deal on eBay.
^^ Yeah, I just used their site to verify the parts numbers were the same. If you've got a better deal on Ebay, jump on it. Your original question was would ones for a 93 work on an 89. I was just trying to quickly answer that question.
Thanks for your advice batstiva and your quick reply! I just want to be 100% sure they will work and from the looks of it they will. I'll also PM the seller and ask his advice. I would have to be stuck with parts that are not compatible with my car.Originally posted by batstiva View Post^^ Yeah, I just used their site to verify the parts numbers were the same. If you've got a better deal on Ebay, jump on it. Your original question was would ones for a 93 work on an 89. I was just trying to quickly answer that question.
The splines on the inner tie rods where they screw into the rack may differ. I bought a set for my 89 festiva, got home, removed my old ones and they were course spline, the ones advance auto sold me were fine spline. Took them back and they ordered the course ones for me. Just check to see what you need before you buy.1960 willys pickup
1967 jeep cj5
1988 festiva
1989 festiva
1990 festiva for parts
1991 s-10
