89 festiva shift lamp problems
  • 89 festiva shift lamp problems
    i have a 89 festiva that will not run when the shift lamp on the dash comes on. sometimes the lamp will be on when i try to start it and it will backfire and not start, but if the shift lamp is off it will start right up.
    any ideas?
    perform an excorcism...
    there's an evil spirit in the distributor cap.
    Jim DeAngelis
      My 89 has something like that. The shift light comes on with the check engine light. The car seems to run fine, but failed emissions really bad once the lights came on. I can't be positive that its because of whatever is triggering the lights, but I think so. The weird thing is, I've pressure washed the motor a couple times, and after each time, the shift and engine lights shut off until the motor got to temp. I assume that its an emissions system thing. Is your car carbureted? Maybe a loose wire somewhere, or a sensor that is going bad. Weird.
      '89 L! -shaved, lowered, 17's, and two 10"subs. B6swap. Candy tangerine, flamed, painted carbon look hood/stripes. AND the roof glows in the dark... That was a dumb idea.
