I had a front wheel bearing go out in my 93 festy. After disassembly I discovered I had no preload spacer in there. Upon searching and according to my service manual there should be one, one of 21 it looks like... Since they are obselete from FoMoCo, where can I source one? How can I determine which one I need? Buying all 21 sizes isn't feasible, or an option. What are my options short of buying a complete spindle at the pull a part?
help or suggestions
I would buy a complete spindle from a junk yard, or, this would be a great time to do an Aspire swap. I suppose you could always tear the other side apart to get the spacer and take it to a machine shop to get it duplicated.
Surely someone on here will sell you a complete spindle assy for cheap.....................Brian
Tonycash has a detailed guide of replacing wheel bearings. It is somewhere here on the boards.---------------------------------------------------
Ran into that on one of my cars. I just changed out the whole side.Originally posted by GUS View PostI have the ford manual on "how", just don't have an actual preload spacer(s)
Member tonycash may have what you need.
Dean
Raleigh, NCThe wife and I are attending this meet. Come convoy with us.Come to the 1st annual "Sunshine Meet" March 20th 2010. Details in the thread below.
http://www.fordfestiva.com/forums/sh...292#post295292
www.festivameets.com
Festiva Convoy video link [url]http://www.youtube.com/watch?v=VyFYJcFBc_g[/urlhttp://www.youtube.com/watch?v=ANbkG...eature=related
3rd Annual Festiva Madness. The largest Festiva Meet ever held of owners and their cars
2009 Festiva Madness link with pictures. 51 Festivas & 4 Aspires from eight states attended.
FM3 short 5 minute clip
Link to a short 5 minute clip http://www.youtube.com/watch?v=VFyy-zxgV5A
http://www.fordfestiva.com/forums/sh...ad.php?t=24695
link to 100s of meets pictures and short video clips.http://s1019.photobucket.com/albums/af316/festivameets/
4th Annual Festiva Madness meet will be held Oct 2, 2010 in Raleigh, NC
Cell is 919-271-5190 deanraleighnc@cs.com
Couldn't tell you without checking a lot more cars for spacers.Originally posted by GUS View PostSo the odds of them both being a #11 spacer are good then?
It shouldn't matter if you install another complete side.
Been running mine two years without problems.
Dean
if it didn't have a spacer it may have not needed one. They are there for the hub not the bearing. The hub is not made to as close of tolerances as the bearings are. Put back what is there...not what is on the other side."FLTG4LIFE" @FINALLEVEL , "PBH"
According to a guy that has done a lot of bearings, the #11 spacer is the most common one. I don't know if that is true or not.Originally posted by GUS View PostSo the odds of them both being a #11 spacer are good then?
You can get another spacer of that size and try it. If it's too long, it can be turned down to a shorter, appropriate length. If it's too short, you can shim it. A machine shop should be able to do the whole job for you.
If it was me, I'd just go get another spindle assembly and start from scratch.
I read here that the spacers are still available from Mazda.
The problem is when I torque it to specs, it is to tight and the wheel heats up. Thats what I believe happened in the first place. So my line of thinking is someone has been in there before I bought the car and lost the spacer.Originally posted by GenevaDirt View Postif it didn't have a spacer it may have not needed one. They are there for the hub not the bearing. The hub is not made to as close of tolerances as the bearings are. Put back what is there...not what is on the other side.93 festiva aka "the sexy"
04 blown GT stang
99 wrangler (in the middle of a 5.2 swap)
