Now that's an ENGINE
  • Now that's an ENGINE
    I have been tinkering around with this for a long time and I am finally ready to drop it in my Festiva.
    I completely rebuilt it, bored the cylinders over, had the crank ground, 3 angle valve job on the head and had it trued and put it all together with a full gasket set.
    I also replaced the timing belt, water pump and clutch.
    When it's done I will have about $800 invested.
    Now, many of you probably think I am crazy to spend $800 on a 1.3L engine for a Festiva but I disagree.
    In my area, eastern NC, cars like this with 100k+ miles easily sell for up $1500.
    I originally paid $900 for the car and if I can drive it to work for the next 4 years I will more then make my money back.
    Looking good, hope your hard work pays off.
    Marc
    marc
    white 93 GL / 5spd
      You should dyno it!
      www.dantheoilman.com
      Go ahead and ask me why
        What did you bore it too?
        :angel12:-Santos
        I Officially Hate Spelling Cow v1.6.0
          hm mm went to dinner and couldn't get this out of my head...
          What co lour did you paint the head and the heat shroud?
          Has i nice gun metal or alloy look to it
          :angel12:-Santos
            It's bored .020" over.
            The head is how it came from the shop once they cleaned it, milled the bottom flat and did the 3 angle valve job, which cost me $105
            I have a glass bead cabinet and I used it to clean up the heat shield and the valve cover.
              Nice! And your right not many people would understand why you went through those lengths but as I like to think, to each their own... So goodluck and I hope that engine never let's you down! Sure looks purty nice! :lol: -Kyle
              Cosmic Blue 2008 Mazdaspeed 3 - Mostly Stock...
              White 1990 Ford Festiva - B6 SOHC powered 50 shot = 14.5 @ 94 mph Gone but not forgotten
              Proud member of Chicken Mechanix Racing
